Lower Control Arm - Suspension and Brake Forum
Lower Control Arm
Monday, October 01, 2007 10:09 PM
I'm going to replace my control arms one of these days. I'm assuming someone on this board has replaced theirs at one point, what was some road blocks that slowed you down? Any form of suggestion would help. Thank you.
Re: Lower Control Arm
Tuesday, October 02, 2007 5:07 AM
The only road block I had is that the passenger side wouldn't separate at the ball joint for me. Problem was solved with a pickle fork and a new ball joint. Pretty painless actually.
Also, you will have to remove the lower engine mount and the brace that goes from the radiator to the sub frame in order to access a horizontal bolt on both sides.
