Okay, so i just ordered springs, bushings, and ball joints.. - Suspension and Brake Forum
Sunday, August 19, 2007 2:56 PM
Is there anything else I should worry about?
I bought the KYB AGX's, and sold my GR-2's. I also bought new eibach sportlines.
Anything else before i throw my car out of alignment?
I'm back from the dead.
Currently Driving: RSX Type-S.
My Cavalier Burnt up :-(
Re: Okay, so i just ordered springs, bushings, and ball joints..
Sunday, August 19, 2007 3:33 PM
You should worry about those Sportlines - they lower your car too much for the struts you bought.
Sunday, August 19, 2007 5:39 PM
Strut mounts would be a good investment as well if they've not already been done, and yeah, Sportlines will void the warranty on the AGX struts, too much drop really for them to handle. The Eibach Prokit is a much better partner for those struts.
Tuesday, August 21, 2007 1:57 PM
Sorry guys, i meant to say Pro Kit. hahahaha i had already heard from everyone else that sportlines weren't the way to go. Also it drops my car too much for CT roads.
But i will def invest in strut mounts
Tuesday, August 21, 2007 2:07 PM
maybe new tie rod ends. then youll have NOTHING to worry about for a while.
Wednesday, August 22, 2007 12:06 AM
Hell, brakes and brake hoses, if you haven't in a while and got the money. lol
Wednesday, August 22, 2007 12:26 PM
Brakes are my next obstacle before my 4 month NON-BUYING hiatus. hahaha.
My girlfriend is making me not spend money on my car for 4 months. For the better of myself, and for her i guess because I'm always broke and she buys me @!#$ all the time.
I would have so much more money if it weren't for modding.
In other words, i would spend more money on my suspension than i would taking her out to dinner.
I could see how that would be annoying.
But tie rod ends, ill order them tonight. I just ordered a set of monroe strut mounts too.
After brakes is fuel system, i just picked up some sweet RC Engineering injectors for 80 dollars from a j-boer.
BUt im thinking of getting the holly suel system from Jegs before i supercharge this beast
Any input on the holly fuel system? (ie Fuel pump, fuel fittings, lines, AFPR)
Sunday, August 26, 2007 9:34 PM
talking about tie rod ends and strut mounts....do you guys recomend replacing with oem parts, or would it be better to get aftermarket? in that case, which brand would you recommend?
* * BIG FOR SALE POST * *
Monday, August 27, 2007 5:49 AM
no need to replace the tie-rods or strut mounts unless there bad. if your doing the work yourself. Strut mounts are easy as pie, tie-rods you should take it to an alignment shop immedietely after. I'm still running on stock tie-rods with 85,000 miles and autoxed it regularly till I blew the engine(rebuilding it now). Tie-rods are still in great shape.
-Chris
Monday, August 27, 2007 10:32 AM
so ill probly get some monroe strut mounts for sure. i havnt heard anyine say anything about the tie rod ends before. the car has 150k miles on it. u dont think they should be replaced? the car currently rides like ass. i am waiting to get all the parts to do it all at once
Tuesday, August 28, 2007 1:34 AM
Moog makes good suspension parts, and KYB also makes strut mounts for the Cavs.
Tuesday, August 28, 2007 10:29 PM
just did mine on saturday, kyb agx's, pro kit, new strut mounts, reused the boot and bump stop, and I was all set,
had an alignment today, and to my surprise(and joy), the camber was dead on after I had lowered it myself, toe was a little out and caster was a hair off, very easy to fix, took them about 25-30 minutes to do.
I was a little worried because it did not look like there was much room to move the struts to adjust the camber, but could not have been any closer to spec then what I had done.
They made the wheel nice and straight and even oiled up the clutch pedal because it was making some noise, what nice guys, and they even saved me about 25-30 bucks.
It was supposed to have been about 90 canadian for an alignment on a lowered car)as it usually takes more of time because of more things to alter, because it went easy, they only charged me 68 including tax.
I have had my vehicle, my sisters, all of my friends and the tire shop I work at recommend them too,
if you are in Calgary Alberta Canada, I suggest you check them out,
Precision Alignment & Brake Ltd
you could not be happier
my results (yes I do need to give it a bath)
Wednesday, August 29, 2007 5:55 AM
If you're doing the struts and springs, just do the mounts at the same time. No sense in puting them in, then having to do the mounts again. That way you're good. The tie rod ends are an option. They're cheap enough, and that will mean that you won't have to align it again when you decide to do them.
I might consider ball joints and control arm bushings, depending on your mileage.
I tend to do everything once I get the suspension half way apart. Usually that also includes paint of some kind.
Other than that, you should be good to go.
