Hi All, i just discovered this site, great!
I am upgrading the suspension on a project car i got: Cavi 2.2L 2002 coupe and i just bought a set of TENZO R GF2 lowering springs which would lower my car about 2 inches (F&R). Any input on the shocks?? how about these springs? any comments?
thnks.
**fresh**
springs are nothing special, pretty low end... the struts are a stock replacement not meant to handle any kind of a drop. Basically you just wasted your money on a garbage setup, the struts will blow pretty quickly and its gonna ride like @!#$, you should have done some research before buying.
but welcome
Hey buddy, than ks for the reply. However, i just bought the springs that's all, and i was looking on some imput about the struts (brands and overall performance) since i know i cant use the stock struts and shock because they are not designed to be low profile.
But thanks for the comment anyways.
**fresh**
heh..got ya there darkstars..Welcome to the org..springs prolly not the best out there..but they will work. As far as struts go koni yellows and tokiko(sp) D-specs are specifically made for lowering..they will set ya back quite a bit. You could pick up some Kyb struts or koni reds for a little cheaper, they may not be ideal, but they should work
