I am lowering my car with eibach pro kit and the kyb agx's, I am planning on replacing the strut mounts and boots too,
outside of the strut mounts and boots is there anything else I need to get?
I looked arround a little but did not find what I was looking for, but I just wanted to be sure, Still need to buy a haynes book or something too.
thanks
I would say the only thing you should need to replace is just the strut mounts. The rubber boot and bump stop should be fine. If you need instructions check out this link.
http://bradiscool.com/spring.html
Regards,
I am just going to keep the factory stuff together, I figured that it would be easier, and quicker to change it out, I won't be able to put it in for about 3 weeks, but I can get the parts together and put it together, and it should only take a little time to have it all together.
that is the plan anyway, it will cost a little more, but what the hell, so it there anything else that I will need out side of the boots, strut mounts, springs and struts?
do I need the isolators, I don't think they are on there now!
