After receiving an email today after placing an order for the Gravana camber plates months ago, I was informed that Gravana will not be proceeding with the pillowball mount setup and that my order had been cancelled. Although I am bummed about it to an extent, it makes me wonder if its possible to mate up camber plates from another setup. Any insight guys?
Proud member of
JBOK (J-bodies of Kentucky)
I went with McMoney's camber plates (shipped out today, thanks!) and I have Held making a set of solid rear strut mounts.Once I receive them, I'll post up some pictures for you to see.
As of now though, this is your only option unless you want to retro fit the pillow ball mounts from the Tein's.
McMoney is still making the plates? I got one of the first sets he made. Excellent plates.
does anyone have a pic of mcmoney's plates and do they work in conjuction with the stock gm strut mounts from 95-99 style?
farmerz24
I would get a set.
<a href = 'http://ivpnewmedia.com/10thst/tifts/'>
<img src = 'http://ivpnewmedia.com/10thst/tifts/dpBanner.gif'></a>
HUM....nice...any link to whom ever makes these.
I thought held was not going to make any more????
I emailed McMoney last week about making some more and he replied that he sold the last set
I was told that I cannot get the Tein camber plates separate from their coilovers
Jason
99 Z24 Supercharged
157hp/171tq - NA
Maybe not for Cavaliers........
MCMONEY!!! make me a set..
do they replace everything but the blac plastic/rubber portion of the strut mount? Im having trouble visualizing this, as the bolts for the rubber/plastic go into the frame. but it looks like mcmoneys piece has its own bolts that go into there.
i jsut want adjustable mounts, as i need to trim my camber due to my n body aluminum arm swap.
thanks!
farmerz24
Yeah, only now they have Ground Controls and Koni Yellows underneath
Its true muffin put his hand on my last set
But if i got anough people I can make a another batch (pre paid this time)
farmerz24 here some picture for you
I'd like a set of those, but how do you get them to work with smaller radius springs (like Zach's Ground Control coilovers) where the bearing is too wide?
There is no need for the OEM bearing on the factory springs. Just get a big washer to put between strut shaft and the plate and then the bearing/washer type thing supplied with the Ground Controls will sit on that washer.
VanquisherOfTheVariance (Zach) wrote:There is no need for the OEM bearing on the factory springs.
* No need for the OEM bearing on 2.5" coilover's (or other small radius setups).
Mcmoney, how many people would you need? And how much at that amount?
Those who have shown interest so far (feel free to remove yourself, obviously):
1. Mike Davis (-MR- LD9)
2. Ryan Thompson
3. Jason McElvy
4. Chris Tataryn (farmerz24)
5. Josh Johnson (OHV notec)
6. Zach Hilton
2. Ryan Thompson
3. Jason McElvy
6. Zach Hilton
7. farmerz24
farmerz24
farmerz24 wrote:1. Mike Davis (-MR- LD9)
2. Ryan Thompson
3. Jason McElvy
6. Zach Hilton
7. farmerz24
You were already on the list
again:
2. Ryan Thompson
3. Jason McElvy
6. Zach Hilton
duh... oops.
these will work with the gravana's correct?
i guess with these its a solid front mount, and you loose the cushining effect of the other mounts, eh?
farmerz24
is this the front mount replacement?? and camber plate?
Got any price man?
McMoney.
these will work with the gravana's eh??
on a side note, im making up something for the rear gravana coilovers to work with the grand am N body rear end swap.. .who would be intersted in this?
farmerz24
if they work with gc's they'd work with the gravana's
any one pm mcmoney yet to get a price ?
