ive got arospeed coils and there 2'' drop but after looking at your guys cars on here most of you look lower on 1.8 springs
front driver
somewhat side view
Your springs may need to "break in" a little.
your low man
and they are coils... they can be adjusted, you sure they are all the way down?
do u have smaller rims and tires ?? i'm not sure if that would matter but it's a thought
4 door civic on the way
i need a daily driver
you could have the sleeve on upside down, causing it not to go all the way down. if its not on upside down, you can always knock off the spring perches.
there just straight 2 inch coils. not coilovers. i am running a 205/40 17 in stead of the 215/45 but up front it just seems to me like it should be lower. i like the back but i wish the front was down like another 3/4". im just wondering cos ther a cheaper spring if maybe i got a different brand it would be better. pics of your cars and what spring/drop would be great. please post.
yeah that doesn't too right man. did you put the spring in upside down?
Those tires are a bit on the short side, they are meant for Civics according to a post in the wheel/tire forum. When you next get rubber, get 215/45/17, or 225/45/17 size tires. Those are the proper upgrade size for the J-bodies.
It looks about right. Tire size will make a hugh difference on the look of the drop as well.
