1. Should I leave it at the hight it comes on?
2. should I leave the dampening the way it comes?
3. To Bolt them in is the stock bolts used or do i need any new bolts?
4. I want the ride as close to stock as possible, i dont care for performance, i want comfort, im sick of performance
5. does the dampening come from the factory at full stiff or full soft?
u arnt going to get a "stock" feel...those are built for performance...not comfort
I <3 3COT3C!
www.IZNTRBL.com
you didn't answer my questions, i will get comfort if i jack them all the way up as they can go and put it at the softest possible setting, that is what im going to do, i dont wanna lower it, i just want a durable and long lasting strut unlike the stocks that last 2 days
well even if they are all the way up....ur still gnna get the same amount of travel outta them, they are built to be stiff at any setting...even if u set the dampening soft they wont get to a stock feel.....they come with solid mounts and no mater what are gnna make some noises, pretty much u are gnna have a stock looking car with a solid suspencion
I <3 3COT3C!
www.IZNTRBL.com
they are linear springs with spring rates that are high, you will not get OEM comfort form coilovers
1QUICKJ wrote:1. Should I leave it at the hight it comes on?
1. i would double check that from the factory the springs are atleast at the same height... they might differ from strut to strut. but as for leaving them, you paid for coilovers, use them!
2. let the struts break in, id say 1000kms, then start playing around with them to see where you like it (i just guessed at 1000, im probably sure its less)
3. to bolt the struts in? IIRC its a direct bolt, i dont see why it wouldnt be?
4. your out of luck.. their coilovers... their designed for performance, not comfort.. lol :p
5. good question... dont know
now, do you have them already? if so anychance in any of the paperwork it has the product numbers for the front and rear upper mounts? lol
15.1@90.34mph
and
now, do you have them already? if so any chance in any of the paperwork it has the product numbers for the front and rear upper mounts? lol
For both, check out www.tein.com
Download the instruction manual for the cavalier pillowball.
And ave all our questions answered.
Basically, you max out the dampening, then bring it back to the middle.
That way your at 'center' hard or soft.
So, anyone in the market for Teins?
-M
