what does polyurethan do for the car? does it improve handling? Is there a kit or do you have to individualy order them?
"HONDA" tech wana-be
http://www.gadomestics.com/
are you talking about the bushings? if so, they are stiffer then the stock rubber bushings. over time the bushings break down. adding the polyurethane ones will improve handling.
you can get the control arm set from car customs. if you want bushings for the front stabilizer bar, then you'd have to seach for that. i think i saw a post not too long ago about where to get them.
Energy Suspension, PST, etc. I guarantee this is all in the FAQ.
James, is this including the rear 3rd gen axle bushings too?
Desert Tuners
I would buy them in a heartbeat if TTR made them, I heard rear trailing arm bushings and I was interested, then RSM was mentioned and I wasn't anymore.
I acually have a set of rsm rear bushing sitting here...id gladly send them to him for some special prize..phil
minus strut mounts, all 3rd gen jbody suspension parts, should be the same.
Double check that though.
whats wrong with the ones from rsm????
many changes in the making
my favorite part about doing bodywork,.......... bondo bugers
like i said mine are up for copy..or improvement..phil
