Please help! how to... - Suspension and Brake Forum
Monday, November 13, 2006 2:36 PM
i know they have post this but it didnt have the directions that i needed.
i bought a vibrant rear strut bar i will post a pic later to confirm that's the one.
i want to know what do i need to put the strut bar?
i have:
  • the additional nuts
  • washers
  • wrench
  • strut bar of course
these are my questions where does it goes?
where you open the trunk to the sides????
when i put one side the other side wont fit the closest hole will go in the screw but the farther point wont reach the bolt or screw.
do i need to lift car or something????
please some help, comments, advice
btw i bought from gravanna so i suppose is the correct one
thank you
Re: Please help! how to...
Monday, November 13, 2006 2:45 PM
take the bar off of the end pieces, put the ends on then reattach the bar, done
Monday, November 13, 2006 2:51 PM
when i tight them up how tight i have to put them? because i think i will be bending if i tight it alot
Monday, November 13, 2006 3:17 PM
Monday, November 13, 2006 3:29 PM
the nuts for the strut mount are 18 ft lbs. the bar with the Allen head i tightened them pretty tight using the Allen head to turn so I wouldn't go over board. there are also the adjusting nuts at the threads closest to the bar that let you adjust for length. once i had everything on i gave that a twist until it was tight. you can only tighten that so far by hand. just don't try to got all Hercules on it and you'll be fine.
Monday, November 13, 2006 3:35 PM
ok thank you very much
Monday, November 13, 2006 3:37 PM
If you still have trouble I'll hook up with ya , maybe Fri i have the evening off
Monday, November 13, 2006 4:30 PM
i finish installing it. i got a question. do i have to have the mounts level up (like the washers wasn't enough and i was thinking using the stock nut as washer but too much work taking it out and is already night)
so if is ok to leave it like tilt it a little side ways or has to be level.
i have also fri off we can met so you can check it to see if it is correctly installed
thank you
Monday, November 13, 2006 4:57 PM
would be just fine
