No Brakes - Suspension and Brake Forum
No Brakes
Wednesday, October 11, 2006 7:47 AM
Hey everyone, my winter beater is a 93 cavalier and I went to move it the other day and realized it had no brakes. The car sat all summer and now when you press the brake pedal it goes all the way to the floor with no pressure. The brakes grab when the pedal is depressed all the way to the floor just enough to stop from a slow roll. Checked the brake fluid and it is full, just checking to see opinions on the matter. Any help is appreciated.
Re: No Brakes
Wednesday, October 11, 2006 8:35 AM
Did you press the pedal a few times to build up pressure? Might just be air in the lines after sitting for a while.
If there's no leak and the fluid is there, try bleeding them.
Re: No Brakes
Wednesday, October 11, 2006 10:16 AM
Yeah, I pumped it quite a bit and still nothing, so like you said, I guess my next option is bleeding them. By the way Weasel, I was in Toronto on August 6 and was leaving after a Jays game and saw your car as we pulled up to a red light, looks good in person
Re: No Brakes
Wednesday, October 11, 2006 5:49 PM
I would start with bleeding them. It could also be a faulty master cylinder I think?
Tell us what happens.
1983 Camaro Z28
Re: No Brakes
Wednesday, October 11, 2006 6:03 PM
Bleed em and check that all the fittings are tight and the lines are in good condition they may have started to dry rot from a combination of sitting and being a 93 (12yr old brakelines). Being this is a winter beater the dry rot and water or air inside the lines is even more posssible as the car is exposed to primarily harsh conditions.
I'd actually just replace the lines, and bleed the system better safe than sorry.
-Chris
Re: No Brakes
Thursday, October 12, 2006 7:04 AM
while your down there you should prob replace the fuel lines too... or check them if your havin a brske line prob. next thing will prob. be the fuel lines
Re: No Brakes
Thursday, October 12, 2006 8:13 AM
blacksunfirese wrote:Yeah, I pumped it quite a bit and still nothing, so like you said, I guess my next option is bleeding them. By the way Weasel, I was in Toronto on August 6 and was leaving after a Jays game and saw your car as we pulled up to a red light, looks good in person
Thanks bro! Hopefully I wasn't driving like an idiot...
I HATE driving in downtown rush hour traffic!
