how low should i go? - Suspension and Brake Forum
Tuesday, August 15, 2006 5:43 PM
haha just like the title says how low should i go for a DD sunfire? I am putting some 17s on soon and i want them to be tucked a bit but this is a DD so i dont want to have slow WAY down over speed bumps but i do want a nice lower ride and how bad will it be when i hit bumps??
Thanks guys
Re: how low should i go?
Tuesday, August 15, 2006 7:32 PM
tucking is ahard task so to speak its going to be expensive, i say your best bet is sportlines and dspecs, thats the best quality ,lowest, well riding suspension, any lower than that you need coilovers, which are for a good set 1000-2000 dollars total
Tuesday, August 15, 2006 7:42 PM
WOW i am not looking to spend that much i was think around 200 400 range or is that just to cheap to lower a car the right way?
Tuesday, August 15, 2006 8:01 PM
yes, maybe you could find some used stuff for minimum $500. You need to do it right and to do it right its kinda pricy.
Wednesday, August 16, 2006 3:08 AM
go for Pro-kit and AGX, that should run you around 500 or so, quaility products and a nice drop for a DD.
Ill make a sig someday
Wednesday, August 16, 2006 3:50 AM
rhodaz24 wrote:go for Pro-kit and AGX, that should run you around 500 or so, quaility products and a nice drop for a DD.
x2
Wednesday, August 16, 2006 7:30 AM
The only way to tuck on a daily driver is with air bags.
As mentioned, since you don't have much to spend, look into the Prokit and AGX combo.
