1. Josh Klein Easy Street w/ digital kit and 2 - 380c Compressors ( and 2 relays )
2. Kyle Reber Bags front Cans rear w/ digital and 450 compressor and 1 gal. accumulator for rear
3. Joe Eazy - Easystreet w/ 10 switches, adjustable fill/dump valves, 380c and 550c compressors, 1/2" lines, 1/2" vlaves, (2) dual needle gauges, 5 gal. tank
4. BaggedCav - Easystreet w/ 10 switch box, (2) dual needle gauges, 3/8" valves with 1/2" lines, 450c viair compressor and 5 gal. tank
5. SpyderWizard - Custom Cylinder setup(Rolled front punch welds and cutom braketry, with 1/2" fill valves 3/8" Dump valves, 2 - 100CF SCUBA tanks regulated to 250PSI, All compression fittings, 2 Switchboxes(one free, one molded in) Remote Up Down, Touchscreen control, Custom 3 gallon high pressure tank
6.brad - Easystreet w/ 10 switch box, (2) dual needle gauges, 3/8" valves with 1/2" lines, 450c viair compressor and 5 gal. tank
7.Mike- easystreets up front custom one off irs rear with slam specialties re-6 3/8" line and valves and engine driven compressor
8. redecocav - Easystreet kit, 10 switch box, (2) dual needle gauges, 3/8" valves with 1/2" lines, Viair 380 Comp, 8gal Tank
9.jason(sndsgood) Easystreet kit standard kit 1/2" lines 1 compressor
10. yellow22 - easystreet kit, 10 switch box, added tank pressure gauge all in pillar, 450 compressor, rolled pinch welds on front and wheel wells gone in back
11. PHATLIER - Easystreet Kit by 2 gen struts (180 PSI rating) street series, 10 switches box, 1/2 air line dot with 1/2 valves size, Chrome tank 5 gallon, Two dual needle gauges and one single needle gauge with 1/4 air line dot, also get MONSTER AIR COMPRESSOR OASIS XD2000 NOT GET ENGINE DRIVEN COMPRESSOR THEY SUCKA BECAUSE OASIS BEAT EVERYTHING AND GIVING YOUR CAR SIMPLE LIFE !
13. James (ROLN19S) - AIM front struts w/Firestone bags - Easystreet Rear sleeve bags - 5gal. Chrome tank - (2) Viair 450's CHROME - (8) 3/8" SMC Valves - 1/2" Parker PTC Fittings - 1/2" DOT airline - (2) Viair dual needle guages (front/rear) - (2)DEI 30amp realys - Kinetik 2000amp battery - 10 switches - Parker Water trap - SMC 1/2" Check valve - TUKIN 19's!!
14. Jeffy (Bagdfire) - Easystreet front strut bags, firestone 2500 bags in rear, shortened rear end 3.5 inches, custom crossmember, fully tubbed tuckin 22s in the rear
15. Scott (Hor) - Easystreet front and rear bags, 10 switch box, DNA 5 gallon tank, (2) Viair 350c compressors, 1/2" fill Valves, 3/8" dump valves, 1/2" lines, Autometer C/F air pressure gauge in pillar, All Nickle plated fittings
16. SEVENONESIXCAVY-Easystreet front bags, Eai rear air cans w/ homemade upper and lower mounts, 1- 5 gal and 1- 3 gal tank,
1/2in valves 1/2in airline, 2 parker water traps, 2 Viar 450c compressors, Eai pressure switch, AVS 5 switch box
i cant believe you guys are using that poopy 10switch box
~SEVENONESIX~CAR CLUB OF WNY EST. 1996
![](http://streetsourcemag.com/chatroom/images/1212200282723PM62340.gif)
check out my cardomain
![](http://suicidedoors.com/welder.gif)
PSSSSSSSSSSSSSST GOT AIR????
