EZ coil over Question - Suspension and Brake Forum
Friday, July 07, 2006 6:13 PM
looking into getting coilovers for my 02 cav... first what would be the best bang for the buck but still with good quality... and also after i put them on do i have to get an alignment every time i adjust the height? thanks again buys
Re: EZ coil over Question
Friday, July 07, 2006 7:17 PM
you dont have to get an alignment everytime everytime you adjust if it is a minor change. I would say anything more than an inch of change get an aligment. Though im sure im probably wrong as hell.
IF you want cheap get koni and ground controlls. You want the best get tein SS
Saturday, July 08, 2006 1:27 PM
you only need an alignment when you remove your struts from the car. changing the height does not require an alignment
Saturday, July 08, 2006 11:02 PM
DayUSeX (ws6+04cav= FTW) wrote:IF you want cheap get koni and ground controlls. You want the best get tein SS
D-Specs + GC is cheaper than Konis, and the cheapest way to do it right. Coils are NOT cheap.
Sunday, July 09, 2006 5:40 AM
Around here, Koni's are cheaper than D-Spec's....
