ok, are the studs that come out of the top of the strut tower just studs or are they bolts?
these..
I thought they were just studs and could be turned out to put longer ones in... like these..
or do they unbolt from under in the wheel well?
Causa latet vis est notissima
DIY Clear 03+ Headlights
no they are studs you can use bolts from the bottom and a bolt it in you need to drill out the stripped stud and get a longer nut and bolt or get new strut mounts
Uh, Time for a new strut mount! Sorry dude but I don't think that can be fixed.
I fixed it :-) looks better than it would of before even... too bad it took all day to do lol
Awesome ! Glad you prooved me wrong.
Jackalope wrote:Awesome ! Glad you prooved me wrong.
well, not exactly wrong, I did have to cut off the existing stud, drill it a tad, then use a punch pin to get the old stud out, then put in a threaded retaining clip, and run the bolts in from the top instead of using nuts...
I stripped mine out too (with a torque wrench!!) I pounded out the stud, stuck a bolt in there and put a litttle weld bead on it to hold it steady. worked great.
Go Go OG Traction!!
I think I would have just bought a new mount lol
Good job on the work though
