Front end noise - new suspension - Suspension and Brake Forum
Thursday, June 08, 2006 5:22 AM
A couple of weeks back, I installed GR-2's, new strut mounts, and control arm bushings. Now when I am driving and hit a medium to large bump, I get a bang or thud from my front right side (I will only happen once per bump, and doesn't happen every time). I double checked everything on the front suspension, and everything seems tight.
The only thing I can see that could be an issue is that the front sway bar is very close to the frame on the right side. I have new bushings all around on the front sway bar (D-links and end links). Does anyone have any ideas?
Thanks!
Re: Front end noise - new suspension
Thursday, June 08, 2006 9:18 AM
Is it possible you're bottoming out the strut??
I know some people get that slightly sportier feel of the GR2s and end up taking bumps and whatnot faster than they used to.
Thursday, June 08, 2006 11:14 AM
No. It actually happens at slower speeds too (i.e. parking lot speeds). Its more likely to happen if I hit a bump while I am turning right.
Thursday, June 08, 2006 4:56 PM
try retightening the struts, i had the same problem, they were a little loose.
