driving yseterday and when i reach around 60mph i feel feedback in the steering wheel like something is loose in the steering susp. i also hear a squeaking noise also when the car goes up and down.got my struts changed 2 months ago and an alignment .i hate this cause when i had the money i told the mechanic if anything else needs to be replaced change it.any suggestion what it could be.
the squeek noise is the strut mounts. you may need new ones. usually strut mounts clunk when you go over bumps but not all the time. in my integra they squeek going over bumps.
as for as the other feeling, im not sure. can you be a little more descriptive on it?
i feel the steering wheel shaking.will not replacing right away cause problems
well at high speeds like that it could be a few things
do you have aftermarket rims? if so you may need hub rings if you dont have them
tires may need to be balanced
