what does everyone think about the progress rear sway bar?
i have a 1998 pontiac sunfire se... and im debating on the addco rear 1 inch, or progress 22mm..... and i know the addco now bolts in using the existing bolts at the bottom of the shocks and has the claps to hold it to the axle... is progress set up the same? im not into drilling..
98' Pontiac Sunfire SE
if you have the stock front sway bar this well work better than the larger addco swaybar. from what ive read the addco sway bar requires more drilling. the progress also requires minor drilling to hold the clamps onto the twist beam no big deal. i just ordered mine from ptuning for 149$ shipped. also some guy posted pics a while back on the whole install i try to find it for you.
15.4 @ 89mph
any other thoughts?
Jared, I had a RKSport 22mm, which is actually Hellwig bar I believe and it was fricking sweet. I loved it.
If you look at that Progress install you will see that the damn thing has no end links, which probably makes it stiffer than RKSport or Eibach bars... that thing must be sweet
CAC2004 FSS#1, 2003,2004 Atlantic FSP #1, 2004 Overall Atlantic #1
i didnt even notice, but your right... hmm
