hey all
im about to drop my car probably this weekend or monday. i have 1.7" springs and dspecs. i have a 2001 sunfire GT, and i have seen posts that when installing the front the top of the strut sits to far up and you cannot tighten the nuts down and need spacers..? is this something that will for sure happen to me or is it random? and if i do need them do i just use washers or special spacers and where do i put them? what size are they?be very specific so i can get them today or tomorrow =)
thx
since you have 00 or up mounts, you will need them. just use washers, but go to the hardware store and get good thick ones. measure the size hole you need it to fit, then measure the clearance to drop it in.
i bought a set when i first got mine, and didnt think about the outer diameter of the washer, and they were too big, so i had to go back and get smaller ones.
when you seat the mount on the strut, put the washers on before you bolt down the nut to the strut rod. thats where the gap is
hope thats clear enough
ps - you'll love the d-specs. very clean install, and amazing ride!!
RIP Saint ........ JBO
oh now i get it.
so i can pretty much do the complete install and when i am finishing it up by tighening the top nuts after i lower the car down, i will need to add a few washers so the nuts will tighten tight enough?
thanks man
^^^exactly!!!
np man! glad i could help
I'll tell you what I did when I installed my D Specs. I have a bench grinder with a cutoff wheel at my work, and I used it to remove the flared section of the OEM strut nuts. I then used those flared pieces as the spacers I needed for the new strut nuts that Tokico provides. What can I say? I'm a bit of a cheap bastard when it comes to stuff like that.
^^thats actually not a half bad idea at all!!
ps - washers are like $0.50 for 4, lol
Well, at the time I was thinking that one solid piece would be better structurally compared to a bunch of thin pieces sandwiched together.....and I'm a cheap bastard.
^Doesn't matter so long as it doesn't compress.
I installed mine this weekend and I didn't need any spacers?? I installed brand new Monroe mounts and 1.4" drop springs... They springs were the same height as the stock springs... My rears already had washers on them so I just transfered those over but the fronts I just used the provided flared lock nuts that came with the struts... Should I be worried??
Knowledge about everything and yet an expert of nothing!!
Jack of all trades.
wtf i didnt you anyway washers for my D-Spec ?
My Car Specs
