easy street airride - Suspension and Brake Forum
easy street airride
Tuesday, April 25, 2006 11:31 PM
Hello everyone, i have a couple questions
1. i have 2 viair 380c compressors and want to fuse the power wire coming from the battery on each line to each copressor, should 30 amp fuses work???
2. for those of you that have sending units for your airride, i have the dakota digital guage and sending units, should i have to ground the senders because my tank isn't welded or bolted to the car?? will the teflon affect the sender not grounding?
3. is there a special toggle switch that i have to get for such a high amp rating for the compressors??
thanks for the help,
jason norwood
gmto2nr
slowfire01
Re: easy street airride
Wednesday, April 26, 2006 8:37 AM
1. 25 or 30 would work fine.
2. Needs to be grounded somewhere, the system should be grounded anyway. Teflon definately messes with electrical conductivity.
3. Most big switches can handle it. Otherwise you can always use relays.
Thursday, April 27, 2006 8:28 AM
for # 3 i just put a little switch in the neg. wire so i didnt have to worry about the power burnin the wires or nething.
