Can i do this - Suspension and Brake Forum
Can i do this
Friday, April 07, 2006 10:53 AM
ON Tein SS suspension can i drop it 1.5 inches and be fine? Will i need to roll the back fender some?
And 1.5 is the recommended lower for best performance correct?
Thanks
Josh
Re: Can i do this
Friday, April 07, 2006 11:51 AM
1.5" should be fine and i dont think you will need to roll your fenders.
1" to 1.5" is the ideal drop for performance. some where between those 2 drops is when the control arm is parallel to the ground which is the best for performance
Re: Can i do this
Friday, April 07, 2006 1:02 PM
awesome thanks. with that and the sway bars and front strut bar i should be good with suspension..
Re: Can i do this
Friday, April 07, 2006 1:22 PM
You may wish to look into a subframe brace as well.
Re: Can i do this
Friday, April 07, 2006 3:27 PM
so with sportlines do you need to roll the fenders? I thik it's 1.7 front and 2.3 back
Best Time 15.917 at 86.86MPH
Re: Can i do this
Friday, April 07, 2006 4:59 PM
firstcar24 wrote:so with sportlines do you need to roll the fenders? I thik it's 1.7 front and 2.3 back
No
Re: Can i do this
Friday, April 07, 2006 6:08 PM
El Fuego ( the grounded one ) wrote:You may wish to look into a subframe brace as well.
will that help me out alot? that keeps the back in striaight right?
