modifications to koni's? - Suspension and Brake Forum
Wednesday, March 29, 2006 7:55 PM
I have a 2001 Sunfire Gt and I have koni yellows front and back, ground control coilovers, and muroe strut mounts front and back, my question is will I need to make any modifications for this set up to work?
Re: modifications to koni's?
Wednesday, March 29, 2006 7:59 PM
You have to cut the struts to install the Konis, but otherwise it's bolt-on.
the only modifications that have to be made are for the front struts. you take the stock strut, cut it, drain the fluid, then place the front koni insert into the stock housing.
Ill make a sig someday
Wednesday, March 29, 2006 8:02 PM
You have to take the spring perch off the rear and put it on the new Konis.
Wednesday, March 29, 2006 11:54 PM
C.T.S wrote:You have to take the spring perch off the rear and put it on the new Konis.
dont u have to put the perches on all aftermarket ones?
Thursday, March 30, 2006 3:24 AM
don't u have to put the perches on all aftermarket ones?
no
Koni install go to page three the pictures work there.
