ok to start i got a pretty bad squeek comeing from the rear right. ive tried to remove the rear drum but theres no success ive tried penetrants,prying,bangingit. i cant get the stupid thing off. and yes the E brake is off.
note: 2003 cavalier Ls
If you have never taken off the drum before there is useually a little metal ring around one of the lug nuts, it's a little hard to see but take a pair of snips and cut it off and you're good to go.
The little clip things like he mentioned or sometimes they just get stuck to the hub and you need to smack the sh-t out of it with a hammer to get it off. Put the lug nuts back on so you do not damage the threads and they hit in between the studs / lug nuts with a hammer and then try. You may need to do this several times.
DO NOT HIT THE DRUM ON ITS EDGE THIS WILL WARP IT.
If it doesn't move at all, take a hammer to it as Jackalope said.
If it moves just a litlle, the shoe has worn a gove in the drum, use screwdrivers to push in on the shoe (between the drum and the backin plate).
julian rodriguez wrote:and yes the E brake is off.
Good. That was going to be my first question.
My guess is that its one of those clips, since its a newer car. But, it could be what CTS said as well, or both.
i love taking drums off
get to bash the @!#$ out of them.
MY 2003 SUNFIRE 15.63@87.86mph
"A N/A ecotec is not gonna give Honda's and Mitsu's that much of a run for their
money unless their blown or bottle fed.GM is still smokin crack!"
~1QWKZ24
www.streetracing.org, 08/2001
LMAO, I had a buddy check my brakes once, and before he checked the backs he said "Have you ever worked on drum brakes, or watched anyone?" I was like "UM, no, why?" Him "Well, it's going to look like I'm breaking your car, but it'll be just fine" :::whacks a few times with the hammer:::
F/S: 2005 KAWASAKI ZX-6R 636, 1103 MILES, $7500 OBO ^^^
Mine didnt have the c clips on the studs when i redid my rear brakes. though i found a hammer is a fun toy.
