Can I Use Grand Am Rear Disk Brakes? - Suspension and Brake Forum
Wednesday, February 01, 2006 8:34 PM
Hi Guys
I dont know if anybody or anybody asked this question now can I use rear disk brakes from a 99+ grand am for my sunfire? and what is all required to do this swap?
Opening Soon Kustom J's
Re: Can I Use Grand Am Rear Disk Brakes?
Thursday, February 02, 2006 5:35 AM
SInce the Grand Am's do not share the same hub bolt pattern as J's, you prolly would need to do a full rear "axle" swap.
Clicky
Or for less hassle, you can do a swap from a Neon with a little bit of machine work.
Neon Swap
Neon Swap -- More info
Thursday, February 02, 2006 6:27 AM
i guess segragationg the stickies jus tinst enough. the sticky at the top will tell you
Thursday, February 02, 2006 11:16 AM
The stickys need to appear in a bight blinking color until you've clicked on them once. That way nobody can miss them.
Friday, February 03, 2006 6:39 PM
I think the Neon disc swap needs to be made a sticky.
Friday, February 03, 2006 7:33 PM
Kardain wrote:I think the Neon disc swap needs to be made a sticky.
a full write up is being worked on from what I know.
Desert Tuners
Friday, February 03, 2006 8:44 PM
I'm still not clear on why the one I already posted isn't good enough. Is it the whole e-brake thing?
Friday, February 03, 2006 9:54 PM
Try giving step by step number instructions, with torque specs, and possible obsicles (like something you would find in a manual); that's all I did.
Saturday, February 04, 2006 10:27 PM
is there any type of bracks that i can make up or not
