abs module repair question - Suspension and Brake Forum
Tuesday, January 31, 2006 7:28 PM
so im taking off my abs module and i cant get the actual abs lines off the module. are these bolts a left hand thread or whats goin gon here?? can someone please help me?? thanks alot!!!! and has anyone ever heard of a code 65-rear motor circuit short to ground???thanks again
joey
Re: abs module repair question
Tuesday, January 31, 2006 8:19 PM
The lines are normal right hand thread. They're probably rusted on. Use the proper size box wrench. Don't use a crecent or pliers or anything like that, you'll strip the nut, and it's very hard to fix.
That code probably means your wires are rotted out somewhere and are touching the body, or the sensor is bad. Problems either way.
