Well, I should be installing me yellows/goldlines this week and I am wondering what I should do next with it? Since I have the stock 24mm front bar I was thinking about the 25.4mm rear bar. I don't autocross at all, but I like to have fun on some curvy roads when I get the chance. What do you think?
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
It wil give you slight oversteer. It can be good if that's what you want. Otherwise, it may be just a bit too large. Up to you really.
keep in mind if you have the FE2 suspension you have the stock rear bar also
id stick with a 3/4" rear bar
Addco makes a 7/8 and a 1" rear sway bar for the J-bodies.
-Aaron
www.TurboTechRacing.com
i have an 05, does it have a rear sway? i didnt think any of the J's came with a rear sway, i am installing the addco 1" next week which will match the 24mm front pretty well i think
How do I know which package I have? Either way if there is a bar back there, its not a sway bar from what I read.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
yeah when i read the faq i didnt think there was one
look at the build data on the spare tire cover , each code is 3 digits , and are in alphabetical order
when you see the F's look for the FE0 , FE1 or FE2
the FE2 has the large front bar , and rear bar
the rear bar is welded into the V chanel of the rear axle
It's not a real sway bar, it's a bit of extra metal in the torsion axle. I can't tell the difference between cars that do and don't have it.
If you want neutral steering you need a slightly larger bar in the front, because the front weights more (thus wanting to sway more). A difference of 2 or 3mm will produce a neutral setup (front being 2-3 larger than the rear).
If they are equal sizes, or the rear is larger, you'll get oversteer.
If the front is larger (stock) you'll get understeer.
I have the Addco front and rear bars. I personally wouldn't want to be without the front bar with a rear sway bar this big (1"). That's just my opinion though.
cts if you cant tell the FE0 or FE1 vs a FE2 something is wrong
lol
ive got 2 sedans with the FE1 , and the g/f has a FE2 , and its a night and day difference
even with the stock FE1 18mm bar and a 3/4" rear aftermarket bar , hers handled better , only time mine felt better was when i moved to 225/45/17's from the stock size 16's
i'm running a 25.4mm rear with the stock fe2 front bar (the 02's had a slightly smaller front bar than the 03+) and my car handles just fine. when i first put the rear on, i had just the stock front bar, a front strut tower brace, and my koni/goldline combo. if you REALLY push the car through a corner, the rear will kick out. i've since added a rear strut tower bar, subframe brace, and poly endlinks to the front bar and it's fairly neutral now.
[quote=97cavie24ls(JDM&00s/c sedans™)]
You don't think there's a weight discrepency? I think the sedan's extra rear end weight could cause what you're feeling.
i dont think the weight difference is that much that it would make a night and day difference
ive been in a 02 Z24 sedan with FE2 , and it handled very similar to her car if not the same
the stock rear bar does help
best i can say is to put the FE0/1 car next to a FE2 , and jack them up and let the rear suspension hang down , and undo the lower shock mounting point
and see which rear axle twists more , and the FE0/1 will flop around like a fish outta water
I would rather have oversteer, Then it would be more like my camaro.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Click the link on the bottom of my sig. See what happens when you have TOO MUCH oversteer in a fwd.
Proud member of
JBOK (J-bodies of Kentucky)
Zach Hilton wrote:Click the link on the bottom of my sig. See what happens when you have TOO MUCH oversteer in a fwd.
i call that running out of talent.
i say get the big bar there and call it done! you will like it! the amount of over-steer can be tuned with strut settings and tire pressure.
see ya!
[quote=97cavie24ls(JDM&00s/c sedans™)]cts if you cant tell the FE0 or FE1 vs a FE2 something is wrong
I said cars that have the FE2 rear axle or not. I've driven a car with the FE2 front (22mm) and the FE0 rear (no metal chunk); feels just the same to me as my FE2 F+R setup.
You're right that anyone can tell the difference between FE0, 1, and 2.
