I have the Easystreet kit and i have a yellow top and im storing my car for the winter and i start it every 15 days or so, well when i left the car 15 days ago i turned everything off, now when i go to start it the batt is dead my int lights dont even come on, does air ride drain even though its not beeing used?
dont know about air ride, but your cd player,and ecu take voltage to store memory, just by a trickle charge they are like 50$ i put one on my camaro all winter starts fine everytime, got mine from summit made by accel
15.4 @ 89mph
Unless you have some sort of parasitic draw, you shouldn't have any problems. KAM (keep alive memory) for both the stereo and ECM draw next to nothing and the car should start months later no problem. Check the amperage draw when the car is off. It sounds like you have something wrong.
Nope its still all connected
disconnect your compressor, I've seen compressors drain batteries over winter quite often
yes yes disconnect the air ride system i keep mine disconnected and only 15 psi in the system when i start my car i hook everything up and the air ride
the compressor will countinue to kick on to keep air in the system that is might be happing to your car
so ya disconnect it
can i haz bondo
