bigger rims - Suspension and Brake Forum
bigger rims
Monday, November 28, 2005 2:51 PM
well im trying to sell my bags and go with lowering springs or coilovers..so if i wanna go with like 18's which struts and shocks can i use cuz i see some say 16" and lower..i dont want that..Thanx in advance
Re: bigger rims
Monday, November 28, 2005 3:10 PM
ANything you want pretty much but, if you go below 1.5"s get some koni's or d spec's.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Re: bigger rims
Monday, November 28, 2005 5:03 PM
wheels have nothin' to do w/ your struts except for the offset on the wheel determining if you hit your strut, other than that it doesnt matter. what does matter is what spring/coil your going to be usin' w/ what strut
Re: bigger rims
Tuesday, November 29, 2005 11:33 AM
I agree with, uh, that person ^^. I'm an aprentice technician so trust me, the only thing you need to worry about is the backspacing, too much and you hit the struts, too little and you rub the fender
"My name is Bruce, I live in a tree, I eat nuts and berries, hee hee hee hee."
Re: bigger rims
Tuesday, November 29, 2005 11:37 AM
correct, the higher the offset, the closer in it gets and the lower the offset the farther out it goes. typically anything from a 38-45 will be good. ive seen some run 35 and im even running a 48 right now
