Is there a relay or fuse somewhere for the pop-up headlight motor? I have tried different motors, and they still don't work .......
Jason
USACi =>146.9db
14.88 @ 90.73MPH =>GM Charger, Motor Mounts, Catback exhaust
No fuse, just the controller, which is protected by a fusible link.
K...this fusable link is a new thing to me. I remember seeing it in the chiltons. Is it just a piece of wire you replace? do you know where it is? or where the controller might be?
Jason
USACi =>146.9db
The controller is mounted to the driver's side strut tower, held on by one upper mount nut. Its a black plastic box. The fusible link is located somewhere close to the battery positive terminal. Its not on the main starter wire, its on another wire, maybe 8 or 10 gauge. It looks like a glass style fuse holder, but a bit bigger, and it doesn't open. Its basically a big, non-replaceable fuse. When it blows, you replace the whole link. I don't have the diagram right in front of me, but I'm pretty sure there are a few other things on the link, so if everything else works fine, its probably the controller.
