maybe i labeled my first post a little vague and seeing as you cant edit posts i figured i'll try again.
check it out let me know what youguys think.
i'll take $1000 for everything!
[quote="gse_turbo"]
[quote="gse_turbo"]
garrett
[quote="gse_turbo"].
parts list off the top of my head...
• C20GET block
• Mahle pistons and rings
• C20GET rods and crank (reconditioned)
• C20GET head (Completely rebuilt)
• new GET cam
• performance followers (stronger then factory)
• new lifters
• GET intake manifold with injectors, fuel rail, TB...
• GET turbo manifold
• T25 (might need rebuilding)
• T25 inlet and down pipe
• T25 oil return
• motor mount bracket
• new oil pump
• new water pump
• new timing belt
• complete rebuild gasket set
• new bearings, crank and piston
• accessories brackets
• ALT if needed
• distributer or DIS block off for the distributer, you can use your coil pack
i'm sure there is more but this is all i can think of for now.
i'll include a price list for each of the parts if you where to buy everything separate like i did.
with the parts and machining i think i spent around $3500 if not more.
garrett
if you spent so much... why sell it?
hell man... I'd put that setup into a winter beater and run it to hell before I let myself lose 2500 bucks.
[ o ][][][][][][][][ o ] coach built xj ( o   [][][][][][][]/  o ) hid wj
PM sent
"Hondas are like tampons, every pussy has one!!!"
urban wrote:if you spent so much... why sell it?
you made a good point but i have a really nice 96 jetta as my beater and i just don't need another project which is what would come of this motor going in any car.
i would also use the money from the motor sale to help pay for the current build.
garrett
I hear ya.... still... it's a real shame.
If you already didn't, post this classified on www.v6z24.com
