engine miss 2.0 - Second Generation Forum
engine miss 2.0
Monday, March 12, 2007 11:06 AM
My sunbird has had a miss the last 10K miles or so. It only does this at low low rpm under load 35mph t/c lockup. It is more like a bucking more than a miss. once the rpm is up it is ok. I checked the wires/ pcv/ vacuum leaks and such. I am getting tired of feathering the throttle until it gets up to speed. Any one else have this problem????? 92 w/2.0 auto
Re: engine miss 2.0
Monday, March 12, 2007 11:12 AM
Also it seems to upshift very early at partial throttle.
Re: engine miss 2.0
Friday, March 16, 2007 2:20 PM
I plugged the vacuum to the egr valve and no change. So now to check other things.
Re: engine miss 2.0
Friday, March 16, 2007 7:21 PM
Do you have any codes? Is your ignition coil weak? Vacuum hose to the MAP sensor cracked? Have you tuned it up lately? How about ran injector cleaner through? With a little more info we may be able to help, and trust me, I help with troubleshooting engines over the phone 8 hours a day 5 days a week.they are diesel engines though...
Re: engine miss 2.0
Saturday, March 17, 2007 4:17 AM
I will check for codes today however I have no ses light on.
Re: engine miss 2.0
Saturday, March 17, 2007 4:31 AM
Scotty Bishop wrote: Is your ignition coil weak?
I think Scotty's right with this one.
I don't own a 2.0 but from past reading on here, this is the most likely
Alont
Re: engine miss 2.0
Sunday, March 18, 2007 1:59 PM
I will look into the coil....no codes. I just bought a '94 sunbird covertible today RUST FREE! so the '92 is going up for sale.
Re: engine miss 2.0
Monday, March 19, 2007 5:37 PM
check the coil pack i had same problem in a mitsubishi
Re: engine miss 2.0
Sunday, March 25, 2007 7:48 PM
hey man unpluf the tcc selonoid and see if the problem goes away alot of times the selonoid stickin can act like a miss in the motor
HORN BROKEN.....WATCH FOR FINGER!!!
Re: engine miss 2.0
Tuesday, March 27, 2007 8:21 AM
The TCC thing would explain the weird shifting points, i know thats common with the 3.1 cars
Re: engine miss 2.0
Tuesday, March 27, 2007 7:55 PM
the tcc kicked my ass on my 90 sunbird after i swapped trannys. the tranny i put in had been sittin in another car for 9 years
the tcc lasted about 3 weeks and then boom so i unplugged it and ran it w no lock up no more problems
Re: engine miss 2.0
Wednesday, March 28, 2007 9:33 AM
Check your spark plug gap, if your plugs are worn out, your ignition coils may have a hard time firing across such a large gap, i had this problem on my 91 2.2 cavalier.
Re: engine miss 2.0
Wednesday, March 28, 2007 12:36 PM
Thanks guys however I sold the '92 bird couple days ago. I am now getting ready to replace the top on the '94 bird I just got.
Re: engine miss 2.0
Friday, April 06, 2007 9:16 AM
In the future, this is probably the TPS (Throttle position sensor). You'd know for sure if you have a scan tool, when they go bad, the TPS percentage doesn't return to 0% when the throttle is released.
