I know alot of people vote against glasspacks, but I am going to but one on my Cavi, and I want to know two things:
Length wise: Is shorter better for backpressure or longer?
Performance vs sound: which will sound deeper short or long , and what are the performance gains or losses that will occur. I have searched for answers to my questions and none have addressed these 2 .
I don't know j-body's yet........but I will!
WELL SHORTER WILL BE BETTER FOR BACKPRESSURE I'M NOT SURE ABOUT SOUND. YOUR BEST BET WOULD BE TO GET THE 'ONE IN THE 'MIDDLE ' FOR ARGUEMENTS SAKE AND TO MEET A HAPPY MEDIUM
AND DON'T WORRY IF ITS NOT AS LOUD AS U EXPECTED WHEN YOU FIRST INSTALL IT, BECAUSE IN 2 WEEKS IT'LL BE A LOT LOUDER
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
if i remember correctly the shorter it is the louder it is
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
Thanks guys I am buying a 17" cherry bomb this weekend since I need to pass inspection next week, and its not hard to cut the bad one off, and slip fit and clamp a cherry bomb on there til after inspection if it blows out.
My friend has 89 2.8L v6 auto cavalier with 2 cherry bomb glass packs it sounds pretty good, the are both 17incher's, Exhaust sounds a bit louder, Even with a stock muffler those cavy's got that rumble sound. He went through Emission testing with no problems.
i run a glass pack as a resinator between my cat and my muffler...
i gained HP due to increased back pressure
it quieted down the muffler but added more a a deep tone to it...
im happy with my set up...
i would say mine is about a 12 - 15" long...
