i need some part numbers for some parts...
ARP 1/2 headstuds and nut kit...
ARP conrod bolts and nuts...
Better rings (if there are any avail)
Lower compression pistons...
Finned oilpan.
Headgasket, that will accept 1/2 headstuds.....
adj cam gear
and approx size people are using for throttlebodies and any modification made to intakes ect....
clutch / pressure plate suggestions....
Lsd? (again maybe)
all this for an Lt3 2.0 turbo... 5spd....
Justin
1st 1st gen on air.....
- not available. I believe potiacjeff used other ARP headstuds, and rethreaded the block.
- 209-6003 ProWave 2000 series
- dont know.
- unless you go custom, I dont believe there is anything available
Finned oilpan.
- I dont quite understand what you mean??
- if you want better one, I'd say FelPro. If you want to best, Cometic C4216-051
adj cam gear
- See the Piper Cams or Kent Cams. Look for 2.0 8V motor (C20NE, C20SEH). These will have to be imported out of Europe
Hope this helps a tad.
![](http://www3.telus.net/GsiTurbo/780/Sig_Logo.jpg)
<a href="www3.telus.net/GsiTurbo" style="text-decoration: none">
<font color="#008080">-= My Website =-</font></a>
finned oilpan (from europe it's apparently an alum oil pan for the lt3 cousin ...
In that case, you need to get oil pan from either Daewoo Nubira or Leganza (make sure its alu, as some of them have same stamped steel as the Sunbird). Also, all new Reno / Forenza have the aluminum oil pans.
