I found a 2nd gen vert at the yard with the front STB still on it. if anyone is interested I can pull it on the way home after work.
What is a strut tower brace/bar?
Strut tower braces or bars are intended to eliminate strut tower deflection and increase chassis rigidity to reduce suspension distortion from acceleration and cornering. The brace also improves the chassis rigidity for better vehicle handling and helps maintain correct suspension geometry.
Strut tower braces are available for either the front or the rear of your J-body, and connect the two strut towers to each other, and sometimes also to the firewall or other parts of the car. The front bars are much more common, though they serve the same purpose. The length of the front and rear bars is different, so unfortunately they are not interchangeable.
sounds like something better bought new?
no, its just a bar. they wertn just on verts, they were also on phase 1 and 2 coupes.
What year 2nd gen? Or more important/easily, which of these bolt circles was it?
It was a sunbird, but it is def a 2nd gen 89-94? i think
Left pic is 92-94, right pic is 88-91.
Elias A wrote:sounds like something better bought new?
teh factory bar is better then the aftermarket ones
![](/global/images/emoticons/ad.gif)
i jsut took 1 off my 91Z that im parting out and threw it on my 90sedan
gonna steal the sway bars from it in the next couple days
![](http://img.photobucket.com/albums/v297/_HeC_/net%20pics/hecsig.jpg)
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
