Has anyone priced out the GM 3 bar map sensor off of the turbo trans-ams? Also does anyone have the part number? Tony, I'm sure you're been here done that... Any one have a good/cheap source? Thanks
1990 Pontiac Sunbird GT turbo
-TGP turbo
-DSM SMIC turned TMIC
-Injectors
1989 3.8 Turbo Trans Am. GM part # 12223861. List is $110.08. I'd wager you could get it at Autozone, Advance auto, Napa, etc.
Tony
Tony
1987 Sunbird GT turbo convert
Ported intake, Fiero 53 MM TB, 52 lb inj, ported and flowed head, tube header, Mitsu TD06, ARP rod
bolts/head studs, adj cam sprocket, 4" x 12" x 31" FMIC, Paxton AFPR, modified 125 trans/LSD
unit/3.42's, custom chip tuning, Alky Control Methanol injection
13.61 ET at 101.44 mph, 262 WHP/350WTQ
2009 Pontiac Solstice GXP roadster, 2.0 turbo w/GMPP exh, CAI and turbo upgrade, 290 hp/325 ft lbs
1969 Olds 442 convert
400 Eng, 200-4R trans, 3.73 posi, power everything, OAI
Haven't found an aftermarket part number yet. GM only. Try gmpartsdirect.com
-->Slow
Thank you, greatly appreciated
-TGP turbo
-Injectors
I bought one for my typhoon. I bought it from a parts store. I think it was Advance Auto. I would have to really dig back into the receits. I think it was only around 65 or so. I went to the dealer to get one, and the best they would do was about 90 dollars. I would have used GMpartsdirect, but I was at a car show in KC and had just installed the new ecu and injectors, it would not run on 2bar.
gmpartsdirect.com wrote:GM PART # 12223861
CATEGORY: Computer Control Sensors
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $114.48
OUR PRICE: $59.53
DESCRIPTION: SENSOR AS
The old 16040749 part number has changed to this 2nd design and will require using a new connector 15305891 when replacing the first design sensor with the new 2nd design map sensor. If you are installing this on a vehicle other than a 1989 turbo T/A there will not be a warranty on this part.
This is an electrical part which is not returnable per our site policies.
2004 Cavalier. Razzi. (Sold)
1998 Corvette. Some mods.
1992 Typhoon. Lots of mods.
1994 Civic VX 44MPG
Thanks! Good info... Why can't they leave a design alone.....
-TGP turbo
-Injectors
They are about 65-75 bucks at the auto parts store they are also used for the Buick GN which is the PN I used to get mine
Yes it is a cavalier deal with it
