ok form what it feels like only one break is working the front drivers side. the car pulls to the left hard when hiting the breaks . the girl i got the car from said it was leaking a lil break fluid and would need the line replaced but the peadle just sinks to the floor but will stop the car any info on what would couse this or be the problem would help out alot so it can be my DD for winter thanks
im also here like some thud noise from the front and like a clicking when i have to hit them hard only sometimes i know for shure its not the cv joints
also my break light and abs light stay on and dont go off
You've got a bad leak somewhere. The lights stay on because the problem is still there. Look on the ground for puddles if that fails pull the wheels and feel around the drums and rotors for fluid.
It could get worse, the brake could lock up. That is never good!
Back In Black '89 RS
"Get In, Sit Down, Shut Up, and Hold On!"
Definately replace the line on the passenger side. When you have it apart look at the break pads, calipers, and rotors for any obvious damage or wear. Does the front end vibrate when you hit the brakes? If so you need rotors, or to at least have the ones on it turned. Look for anything loose in the front end when you have the wheels off. That noise could be alot of things, but I would look at your end links first since I had one do that and it ended up that the end link on one side had rusted through.
ok thanks ill cheack today to see if i can find the leak and hope that will solve the problem
