Ok... here is the problem... i will start my car let it run awhile then go to back out of my drive way and it grinds into reverse with the clutch 100 percent to the floor i can be doing anything and try to put it in reverse and still grinds into gear or else its hard to get in... also my first second and third are also hard to get in but not so bad and i dont get grinding at all its just stiff... if anyone knows what might be going on please tell me because i want to get this fixed i love my car even though it looks like crap!!
thanks jeremy
Sounds like a badly worn pressure plate.
sounds more like a hydralic issue. check out your master and slave cylender for leaks. they will leak from were the pushrod goes int othe slave/master. also check the level in the master, if its low, its gotta be leaking somewere.
