quad 4 2.3 in a second gen - Second Generation Forum
Wednesday, October 12, 2005 11:17 PM
ok i have a block from a 2.3 out of a 94 pontiac and i want to know how much work it will be to install in my car with a 5 speed tranny... also i want to get everything together to run a turbo set up on... i am really interested in this and am willing to dump money into this!! just i need the resources please help me out if possible
jeremy
**Wisconsin J's!**
1992 Chevy Cavy Phase 2 Woohoo- Some Mods...
1997 Chevy Cavy - Intake
Looking For A Stock Phase 1 Z Kit Bumpers N Skirts! And Light Assembly And Mounting Brackets For The 92
Btchinj@hotmail.com & Btchinj@yahoo.com
Re: quad 4 2.3 in a second gen
Thursday, October 13, 2005 4:01 AM
its been done b4 i was thinking about it but from what i read its a pita...try contacting the people in this forum about it http://www.v6z24.com/jbodyforum/viewtopic.php?t=55647 theres a couple that did the swap lots of custom work needed for it though
Thursday, October 13, 2005 5:43 AM
I doesn't require any more work than a 3400 swap (which is pretty simple). Besides the basic wiring changes, all thats needed is a new rear engine mount welded in. The link provided is the one I would direct you too also.
Thursday, October 13, 2005 7:21 AM
is it worth it ?
**Wisconsin J's!**
i also for got its not the high output
**Wisconsin J's!**
Thursday, October 13, 2005 11:38 AM
you also need the subframe out of a beretta or grand am that came with a quad.. there is a motor mount attached to it.
Best bet is to find a wrecked beretta with the quad and swap everything over.
Thursday, October 13, 2005 12:24 PM
I think it was a tranny mount that has to be welded in, theres a post on this somewere on this forum were I posted a how to on this swap that was given to me by a guy who has done the swap. I'd post it again but I dont have it on my comp anymore, just do a search, You'll find it.
Thursday, October 13, 2005 6:29 PM
If its not an HO, its not worth it IMO. The 2.3/2.4 has too many oil system problems to warrant a base engine swap. It is, however, very worth it if it is the HO. The power to weight ratio is better than a 3400, and the difficulty of the swap is the same. I guess its all about what you want and how much effort you want to put into it.
Thursday, October 13, 2005 7:02 PM
I wouldn't neccesarily say the difficulty is the same.. if you are starting with a v6 car putting in the 3400 is cake. the only wiring is the injector harness and moving some wire around in the loom.
If you do the quad 4 you have the harness to swap, ecm, transmission, axels, subframe, and the gauge cluster may never work right again.
If you are starting with a 4cylinder car then the swap would be the same.
Thursday, October 13, 2005 10:23 PM
if its a h.o or a w41 it would be worth it due to the weight ratio besides the oil issues its a great motor a buddy of mine know someone that has a twin turbo quad 4 they can take alot of abuse maybe you could look into building up to h.o. specs i know some parts are still available from gm and they arent that expensive also for more info look on http://www.quad4forums.com/
Sunday, October 16, 2005 5:29 AM
Oiling problem with teh 2.3? hahahahaha, please stop now. The 2.3 doesn't have 1 problem with oiling.
Btw, pezed, he doesn't need the subframe. 92+ 2.3had the same mount as the 2.4. Only the 87-91 2.3 had the front mount.
Gilles
2.3 Ho
Sunday, October 16, 2005 9:57 AM
ok but then it may be best to go out and ind an 87-91 and get the subframe and mount, it would simplify the swap.
the 2.3 doesnt have oiling problems, however the HO is notorious for head gaskety failure.
a buddy of mine did the 2.3 ho swap. the car was pretty quick for the 3 hours it lasted til it soun a rod bearing
Tuesday, October 18, 2005 8:36 PM
a name to look for: speedvisioncavalier
Have you seen the turbo wagon?
13.90 @ 105.46mph
street tires
rough tune
Thursday, October 27, 2005 11:48 AM
jux wrote:a name to look for: speedvisioncavalier
You are correct sir!
Saturday, October 29, 2005 11:53 AM
The swap is not difficult, you just need to find a donar GTZ.
The only "fabrication" required is removing the trans mount bracket off the unibody on the GTZ and welding it on the unibody of the 2nd gen.
Everything else bolts in, except the harness stuff which time consuming more than it is difficult. A membership to alldata.com or a GM service manual for GTZ is allot of help with the harness transfer.
I think SVC is on his second one now. I did one with his help via a few emails.
Go to the quad4forums and register. I'm not sure it will let in the tech write up forum otherwise.
http://www.quad4forums.com/forums/forumdisplay.php?s=&forumid=7
I've posted a bunch of stuff there under screen name quadswap.
