Does anyone know where I can find poly engine and transmission mounts at a lower cost than what J body performance asks for.
Go to advance auto parts and buy a tube of urethane made for installing windshields. Just fill your mounts. I've done that on a couple engines and you can really feel the difference. Plus, it is cheap.
Cardomain|
Myspace
yeah i filled mine with it.. its 3m Window Weld
Its not the same as real poly mounts, but at least you wont rip the front engine mount out every 6 months.
^^^^^but searching would have also shown him that turbo mounts are different than non turbo and auto are different from manual.
Cardomain|
Myspace
But only the part number is different. All of them will still bolt into the same spot.
Actually the one thing I hate about the 2.0 turbo motor is it actually uses the same mount as the 2.0 (non turbo).....So my engine has a bit too much play. Oh well, I just purchased a polyurethane transmission mount from Jbody performance. I recently installed a stock front engine mount, except I filled up the upen spots with polyurethane from home depot.........that worked great, Now im just waiting for the trans mount and Ill be set.
