Best source for a factory rear sway bar? - Second Generation Forum
Saturday, September 10, 2005 4:05 AM
I'm looking for a factory rear sway bar for a 93 Cavalier. I must have looked at 50 2nd gen Cavaliers and Sunbirds at junkyards and none of them had the rear bars.
Are any other cars interchangable, and also are they a completely unbolt and bolt onto another car part... or will it require fabrication?
TIA for any thoughts.
JLP
Re: Best source for a factory rear sway bar?
Saturday, September 10, 2005 5:15 AM
Bars off Berettas, Corsica, older Grand Am, olds calias (Nbody) will fit.
The jbodies to be looking for are Z24s and sunbird GTs.
Monday, September 12, 2005 1:32 PM
I bet its only about $35-45 dollars brand new at the dealer. I know the front 30mm bar was only that much.
Monday, September 12, 2005 3:59 PM
Yep, look at the Z24's. I just pulled one off a 90 Z24 only to find it was rusted underneath the rubber bushings it mounted between on the axle ends. I'm searching for a nice one and I'm sure I'll find it.
Good luck searching the local yards. That's your best bet.
-Daryl Scott
*1986 Cavalier RS convertible
<A HREF="http://www.geocities.com/doctorsvt/cav.html"><img src="http://img182.imageshack.us/img182/7373/imag00220fx.jpg">
Tuesday, September 13, 2005 4:24 PM
Found one!
Its actually pretty clean, and it came off an 89 Buick Skylark. Now to go put it on when the rain breaks for a few minutes...
JLP
Tuesday, September 13, 2005 9:18 PM
James Cahill wrote:I bet its only about $35-45 dollars brand new at the dealer. I know the front 30mm bar was only that much.
Are those still stocked at the dealer? Anyone have the part #?
http://cavalierman93.googlepages.com/
Wednesday, September 14, 2005 1:39 PM
Front-
22mm- 22596725 (only fits 4 cyl 88-94) ($63)
28mm- 22596727 (only fits 4 cyl 88-94) ($61)
28mm- 14076613 (only fits 6 cyl 88-93) (updated #)
28mm- 22596731 (only fits 6 cyl 94) (not found)
30mm- 14076614 (only fits 6 cyl 88-93) (updated #)
30mm- 22596732 (only fits 6 cyl 94) ($63)
Rear-
19mm- 22536401 (fits all 88-94) (not found)
21mm- 22536402 (fits all 88-94) (not found)
Keep in mind that you can use a 6 cyl bar on a 4 cyl and vice versa, as long as you have the exhaust rebent to clear the bar. The part # differences between 88-93 and 94 are just to update the number. You can use a 94 bar on an 88-93 car no problem.
I just did a quick GMPD check for these numbers. I guess the prices have gone up. When I wrote not found, that means GMPD can't get it, but it doesn't mean the dealer can't.
I have all the bushing part numbers also, but since they're available aftermarket (both performance and stock grade) I didn't write them all out.
Wednesday, September 14, 2005 9:10 PM
