Who does chips, e-proms - First Generation Forum
Thursday, July 31, 2008 1:00 PM
I just picked up a couple of weeks ago a 87 Skyhawk Turbo and 89 Sunbird Turbo and was wondering
if anything can be done to or who can do the ECM like e-prom changes like we can for my 87 Buick T/R??
thanks
Ron
Emmett, Id. 87T/R 11.69@117
Re: Who does chips, e-proms
Saturday, September 13, 2008 11:53 PM
Hi, Ron.
Your car should have a 1227749 ecm which is the same as what's used in the GMC Syclone and Typhoon. Some of the early turbo 'Birds used a different mask id so you may need to switch to using later code. If you're really into coding you can look into using $59 which is a modified version of the factory $58 and has a support group at code59.org. If you want to stick with stock you can find definition files from Tunercat, Tunerpro, Promgrammer, and maybe even some others.
-->Slow
