I'm trying to figure out what relays I might need to change, and also wanted to find out what they are all for.
I have one on the Drivers fender, near the washer bottle GM#10027698
Two on the drivers firewall GM# 10032082, and 14103379
And three by the passanger firewall GM#10040035, 10040035, and a Bosch one that says 12V 20/30A with the part# 0332204171
Are any of these for the flip up headlight motors?...or is there another one hidden somewhere for them? What are they all for?
Jason
![](http://registry.gmenthusiast.com/images/2k1blackz/personal_pic.jpg)
USACi =>146.9db
14.88 @ 90.73MPH =>GM Charger, Motor Mounts, Catback exhaust
Driver fender one is for the foglights.
Firewall is probably the wiper motor speed control. I'd need pics of the others. The headlight doors are controlled by a module on the shock tower.
Yeah...the 2 on the drivers side are between that module, and the brake booster.....the 3 on the passanger side are right in the corner behind the strut tower........if that helps any?
Jason
USACi =>146.9db
One of the three on the passenger (or right) side is for the fuel pump. Might help if you had a Haynes book or such that could tell you what each is and the wire colors for each one.
Blind Julius
<img src="http://registry.gmenthusiast.com/images/blindjulius/personal_pic.jpg" width=180 height=165>
"Oh! My My!" Splat . . . "Damn Squirrel ! ! !"
^^wow...I didn't even realize you were still on the .org........I have a chiltons, but it doesn't have any wiring diagrams
Thanks though that still helps
Jason
USACi =>146.9db
Yeah, it's has been a long time. I got pretty sick in spring 05 and have been in and out of the hospital a bunch of times. Lost my left leg to infection and now have an artificial one and I'm learning to walk again. I have a new respect for babies... when they fall down they laugh and giggle because they're so much lower to the ground and padded so well. As for me.... when I fall down I break something. I'll be lurking around some and if I can help I will.
Blind Julius
Sorry to hear that....glad your getting through it ok though.
Jason
USACi =>146.9db
