axle hub - First Generation Forum
axle hub
Monday, July 04, 2005 10:11 PM
I was just wondering how hard is it to replace the axle hub where the lug nuts screw onto? Also does anyone have a driver-side Z24 sideskirt and rear lower trim hangin around? Thanks
Re: axle hub
Tuesday, July 05, 2005 6:53 AM
Hub is actually easy to replace. Problem is (?) from the list of body parts you need, that you musta whacked something "really" hard. If that's the case, better check & see if axle itself isn't bent. Might even find a good used axle assy. in junkyard for less than a new hub would cost :>
Alan
Re: axle hub
Tuesday, July 05, 2005 1:31 PM
Well in some aspects I wish I did whack something because that would mean I was driving the car already. I just obtained a 1987 Z24 off my neighbor. The car has some rust but not as much as id thought it to have for sitting in their backyard for 6 years. The hub is missing screws for the lugnuts because they rusted off. The car is missing the drivers side skirt and the Z24 rear trim on the bumper is broken . Don't know if the car runs yet but if it doesnt I hope to get it running.
Anyone replace the headliner in their car?, would a 2nd get headliner fit in a 1st gen. Thanks
Re: axle hub
Tuesday, July 05, 2005 2:16 PM
"The hub is missing screws for the lugnuts because they rusted off."
" IF" by screws you mean the studs that the lugnuts spin onto, these can be replaced. Big hammer...bang on old stud :> drive out old ones. Line-up splines in new ones, and use a lugnut with washers under it and draw/pull stud(s) back into hub. Look behind hub face to see if the studs are "ALL" the way in. All done, cost less than dinner at BK.
Re: axle hub
Tuesday, July 05, 2005 4:24 PM
Headliners cost $60-100 to have done at a shop. You can repair yours if the adhesive is gone, but it usually involves a can of 3M Super 77 Spray Adhesive and a lot of mess.
A used one from a 1st gen should fit, but most likely it will sag, too after a year or so
-Daryl Scott
<A HREF="http://www.geocities.com/doctorsvt/cav.html">*86 Cavalier RS convertible
<A HREF="http://www.geocities.com/doctorsvt/scx.html">*92 Olds Achieva SCX- SOLD...sort of.
<A HREF="http://www.geocities.com/doctorsvt/cobra.html">*98 Mustang SVT Cobra #503</A>
<A HREF="http://www.geocities.com/doctorsvt/sarahcav.html">*01 Cavalier LS Sedan</A>
<A HREF="http://www.geocities.com/doctorsvt/cav.html"><img src="http://www.j-body.org/registry/monkeyspunk79/thumbnail_suncav.JPG"></A> <A HREF="http://www.geocities.com/doctorsvt/scx.html"><img src="http://www.j-body.org/registry/monkeyspunk79/thumbnail_SCX%20side.JPG"> </A> <A HREF="http://www.geocities.com/doctorsvt/scx.html">
<A HREF="http://www.geocities.com/doctorsvt">Top Down, Tank Full, Pockets Empty
