So I swapped my trunk lid for one with a spoiler a few years back. The trunk lid never popped up (or stayed up) like it used to before the spoiler was added. It was a minor annoyance that was pretty far down on the list. Well, in the spirit of messing with absolutely everything on this car, I pulled my subwoofer out and crawled in the trunk, shut the lid, and went to work. Took about 10 minutes to figure out some good leverage points. I just used a long 3/8 socket extension to pop the end of the rob down to the lowest setting.
Thats all that was needed. Sometimes it can be easy. I did have the family check on me in the event that I locked myself in (no glow-in-the-dark handle on my 84
On the downside, at the great angle I was in, I noticed some rust on the inside of the trunk lid that will need to be addressed and I decided to re-wire my subwoofer to use its crossover capablity instead of the separate crossover method I am currently using.
I wouldn't have figured that little spoiler would ruin the counterbalancing act on the deck lid.
Now something much bigger like I have, I doubt there's any hope. I'll have to take a look at your solution to see if it would do me any good.
Easy the balance is set for no wing even as light as the wing is its where its placed on the lid that offsets the balance so there for tgw weight is doubled.
I would not have believed it either until I did it
I will take a pic and post - pretty simple stuff though...
Here is a pic...
I moved it from the top notch to the bottom.
Nice work Paul!
Tony
1987 Sunbird GT turbo convert
Ported intake, Fiero 53 MM TB, 52 lb inj, ported and flowed head, tube header, Mitsu TD06, ARP rod
bolts/head studs, adj cam sprocket, 4" x 12" x 31" FMIC, Paxton AFPR, modified 125 trans/LSD
unit/3.42's, custom chip tuning, Alky Control Methanol injection
13.61 ET at 101.44 mph, 262 WHP/350WTQ
2009 Pontiac Solstice GXP roadster, 2.0 turbo w/GMPP exh, CAI and turbo upgrade, 290 hp/325 ft lbs
1969 Olds 442 convert
400 Eng, 200-4R trans, 3.73 posi, power everything, OAI
Thanks Tony-
I have to declare victory where I can on the easy jobs
