Anyone know where to source a molded PS reservoir hose for my 84 2000 Sunbird Turbo? Heater hose will work but it collapses, and those coil things look pretty stupid.
Ron?
Any assistance appreciated.
Thanks!
Let me do my homework on that one.I have been working my a-- off at the u pull it today for 2 doors,some side glass(plus ALL the hardware even the the slotted brackets that hold it in at the pillar toward the doors).Anyway let me see what I can do,heck I am GOING back to another yard thurs and will scope it for a used one,if need be.I will post back.The junk yard 1st gen guy.
Ron-
Thanks! Are you still working on that Z24 you got the sweet parts off of? Keep going man - get it all... Is Sunny going to turn into a Z?
ok, well I found it... It does not reference to an 84 Pontiac 2000 Sunbird LE, but it does show for an 82-88 Buick Skyhawk T-Type with a 1.8 Turbo. Close enough for me
$15.xx shipped
Edelmann 80163 Power Steering Reservoir Line
I found the lines NO problem on advance auto using ur specs 84 sunbird,1.8 ohc turbo.The sell both the hardline part 71213 for 13.99 OR the return hose to resevoir part# 71351 for 17.99. I guess u can check online with them to see it.But they are available.Glad u located said item.As for the Z kit stuff keeping as extra parts being they are no longer made.Keeping sunny stock for age and original factor.I have picked that 86 Z clean of most of the items I wanted.I may go back and dig into it some more who knows.
Ron - Yes advance had the pressure line and the return line - I checked there first
. I needed the third line from reservoir to pump...
Reservoir hose is on, the fluid is toast. If I try and flush it I am sure the return line will crumble in my hand. Looks like I will use Rons part reference for the return line after all
Good fun never seems to stop does it! I know your aggrevation fix one item then gets umm bigger.Glad I posted the parts before hand just for reference.
