Question about front end swap - North East Region Forum
Friday, February 29, 2008 11:05 AM
This is directed to anyone who has swapped from a 95-02 Sunfire to an 03-05 cavalier. Do your headlights keep blowing out? Everytime I replace a bulp within weeks, Its out again and it switches back and forth between both lights, this never happened when it was just a sunfire.
Re: Question about front end swap
Friday, February 29, 2008 11:14 AM
your wiring is wrong
Friday, February 29, 2008 11:19 AM
In the forum titled front end swap it says you don't have to change the wiring, and the lights fit in there. Im confused
Friday, February 29, 2008 11:32 AM
Hrothgar (zack) wrote:your wiring is wrong
there shouldnt be any wiring involved. both use 9007 bulbs so its plug and play
did you happen to do ANYTHING with the stock wiring when doing the swap?
Friday, February 29, 2008 1:04 PM
what else could it be, whether there is a shorted wire, corrosion, bad connection...the wiring is wrong/bad
Friday, February 29, 2008 7:17 PM
did you somehow cut or nick a wire when you were messing with stuff?
95+ Cavalier and Sunfire Convertible Service Manual! A must read for vert owners!
Friday, February 29, 2008 8:50 PM
Thats what it sounds like to me, like its grounding out and blowin the bulb.
Kandace go out and run your fingers over the wiring as far as you can and make sure there is no cuts on the wire coating.
