how hard do u think it is to go to a stick trans from an auto?
very, semi costly and time consuming
and why is this in NE
$150 in parts $200 in laber
it cost way more than 350 to do the swap i can tell you that. maybe 350 if you know how to do it yourself. its not an easy plug and play task
I spent about 2500. I did buy alot of new parts (including the tranny). Not too easy but doable. I am a backyard mech so if I can do it by myself you should be able to. Shopping around for parts could save you a bundle of cash. Good luck.
Labrat
yea but the only hard part about it would be the cutting of the firewall to add the other pedal
That's not that hard. Just a hole saw and two new bolt holes.
Labrat
true and it is a possible swap to do but its just time consuming. probably will be a weekend thing and i know it has to cost more than 350.
if you have a z24 dont even bother unless the tranny is shot, i never had any problems laying down 1/4 times similar to 5spds
for 2.2 and 2200 its a different story, they are slow as balls with the 3spd compared to the 5...@!#$, both of them are just slow
another thing you gotta figure is if you are going to swap it you might as well do clutch/flywheel at the same time and get the most out of the swap so cost is gonna get to be up there pretty good. You figure 300-500 for the tranny, linkage, pedals, ecu, and all that stuff then you gotta figure in a new clutch and flywheel and short shifter if youd like...you could be looking at 1000-1500 if you want to do it right. Or like mentioned above, 300-500 for the swap alone but the condition of the clutch/flywheel isnt guarenteed. You are going to need the flywheel no matter what because you will have to remove the automatic flywheel.
2007 GM Tuner Bash...HELL YEA
PA,MD,NJ,DE,NY and all states north caravan
you shouldn't have to cut a hole in the fire wall for the tranny. most vehicle already ahve all the stuff there to do a swap. just have to buy the stuf needed and install it. Because a vehicle isn't deteremined to be auto or stick till after the body of the car is made so all that stuff for an auto is there and so isn't it for a manual. definately between $1000 to $2500 for doing it yourself. Maybe more or less depending on how you choose to go part wise.
