well its hard to sue what isnt around, called thier number today and got some indian lady at a gas station
so heres the list
Supercharger Kit (other than the leaking drive housing which with some mechanical know how im sure can be fixed, is perfect) $1500 bucks, ill even HP tune you, you need to have the battery in the trunk and reroute some coolant hoses, also I will include the pre tapped oil pan, this is a steal, my loss is your gain
Wilwood Brakes $700, will need to do brake swap with you as my spindles are already modified to accept the huge wilwood calipers, this also includes the stainless brake lines from wilwood not included originally in the kit
Tein Super Street Suspension, barely 2 months old still green and clean (this does not include my Dampa Chi plush), accepts EDFC, will need to swap for stock suspension since I need something to drive on $1100
MSD DIS 2 Ignition System pre wired for the ecotec, includes icm connectors, msd cam sync $400
RK Sport upper engine mount Ecotec $75
RK Sport lower engine mount $30 will fit any 95-05 J
RK Sport Fiberglass Ram Air hood $300 will need your stock hood, has nick in a corner can easily be fixed as you will most likely need to get it repainted for your car anyway to match
17 inch Konig Verdict Opal Silver Wheels with Kumho Ecsta Supra Tires, rear is almost new, fronts about 50% tread, includes hub centric rings to fit J body Hubs $500, these cannot be sold until the brakes are sold, will swap for stock Z24 or LS Sport rims with decent tread left for less cash
Addco 25.4mm Rear Sway Bar $100
GM Front Strut Tower Brace $30
Vibrant Rear Strut tower Brace $50
Aeromotive Adjustable LT-1 Fuel Presssure Regulator $120 direct bolt on for 03-05 ecotecs, great for boosted setups
RSM 62mm Throttle Body $120
Lotek Triple guage pod, will swap for dark grey stock pillar 95-02
Pioneer Avic N1 Head Unit with DTS Controller and DTS 5.1 Surround sound processor $750 , this thing has DVD Navagation, plays DVDs, Mp3s, can hook up monitors, can hook in video sources, will work with any Pioneer IP Bus accessories, does just about everything a head unit can do
Moble Spec 3 Farad Cap, dirty $50 bucks
Audiobahn 2300HCT Amp needs a good polishing and output RCAs do not work, this is only an issue if your piggybacking amps but since its 2400w RMS at 1ohm it pounds just about anything out there so you usually dont need another amp $200, this is the amp i use for subs, 2 channel and 1ohm stable
Audiobahn 4601T Amp 4 Channel amp 250x4 at 4ohm, 350x4 at 2ohm, this is strong enough to be used for speakers or subs, all chrome lights up all in blue, needs a good polishing $250
Infinity 5.25 inch Perfect 5.1 components originally paid 280 for these , the speaker dust caps have a dent, work perfectly though $100
