will 18's fit on a 1999 cav lowered 2 inches, without rubbing?
Yeah they should but U wanna make sure first do some checking with others too.
Wrong Forum.............might want to check the wheel &tire or suspension &brake forums, but anyways they should fit it depends on your offset...........i have 19's on mine and i ride around with a 2.5" to 3" drop daily so you should be alright...........my roommate has 18's and the same coils as i do so you should be good.
all depends on the width of the rim, the offset any your suspension set up. i would say go w/ a 18x7.5 and you should be able to run an offset from 35-45mm
