I've owned this car for about 8 years now. I bought the car completely stock and it is originally a South Carolina car, it has never seen a single winter and in the time I have owned it I've probably driven it in rain maybe 10 times total. The car is stupid clean inside and out as well as the underside and suspension (if needed I will gladly take pics). The body of the car has right at 100k miles on it and the current built engine has maybe 10k on it if that.
I made the decision to build and turbo this car about 5 years ago and no expense was spared during the build as you can see from the mods list below. I loved the car and it is an absolute monster in terms of power (will break the tires loose at literally 90+mph) but I simply no longer drive the car anymore and have just lost interest... I have had it out a total of 2 times this entire season so it's time to either sell it or start parting it out to try to get back at least some of what I have into it.
Right now the car is tuned to run on both 110 octane @ 32psi and 93 pump gas @ 28psi. I also have a progressive methanol injection kit on the car that I just have not had the time to tune for this season. The tune on the car is very decent and driveability is what I would say close to as good as you will get with a car like this, no bucking, studdering, hanging idle issues etc. I have put NUMEROUS hours into tuning this car and doing my very best to get it dialed in to where I was happy with it, I have driven the car a few hundred miles in a weekend a few times for car shows and never had an issue but of course with that being said I am not a professional tuner so I have no doubt there could be more done with it if you so chose to do so.
I do not have any current dyno numbers for the car and I do not track this car, I built it simply as a street car that would handle all of the imports around my area and it does so with ease. The car did dyno about 3 years ago on a smaller t60-1 turbo, smaller injectors and 15psi of boost and put down 380whp/370wtq. My best guess right now on the current setup and its current boost levels would be upper 400's conservatively. Any questions please do not hesitate to ask and I will be more than happy to try to answer them.
I am looking for
$8,500 for the car and the price is fairly firm so please do not attempt to low ball me as there is no point. I am simply making an attempt to sell the car as a whole first but if it does not sell I already have plans to part out the entire engine and turbo setup to return the car back to a stock engine and then sell it from there.
Engine Mods:
Fully built and balanced 2.4LD9 engine
-Engine bored .020 over
-9.0.1 Compression Wiseco Pistons (.020) overbore
-Custom Grind Camshafts - 7500rpm redline
-Fully built head w/ 1mm oversized valves, titanium retainers, valve springs, and fully ported and exhaust side polished
-Mantapart high rev lifters
-Eagle H Beam Connecting Rods
-Knife edged crankshaft
-Melling 2.3 HO Oil Pump Conversion
-Extensive oil galley porting
-ARP Head and Main Studs
-Cometic .074 Head Gasket
-Clevite 77 rod and main bearings
-Balance shaft removal
-Custom windage tray
-Fully polished HO Intake Manifold (Internally ported)
-62mm TB
-MSD Coils/MSD Wires
-Lightweight Interstate drycell battery
-Precision SC61 .82a/r turbo
-Custom Tubular Equal Length Turbo manifold with ext. wastegate (Fetter header)
-Tial 38mm wastegate
-Synapse BOV
-Vibrant Performance FMIC 28" x 7.5" x 3.5"
-2.5" Custom Charge piping (Aluminium)
-3" Custom downpipe (Stainless)
-Vibrant performance 2.75" stainless exhaust
-Bosch 1050cc Saturated Fuel Injectors
-Casper Billet AFPR
-Walbro 255lph In tank Fuel Pump
-Bosch 044 300lph inline fuel pump
-8AN braided fuel line from tank to fuel rail
-Jegs billet inline fuel filter
-GM 3 Bar Map Sensor (for progressive meth kit control)
-Hallman manual boost controller
-HPTuners custom tuned
-PLX-300 Tuner Edition Wideband
-Cruise control and a/c system removed
Transmission Mods:
-Custom swapped NVG T550 Transmission
-B&M Short Throw Shifter
-ACT Stage 5 4 puck solid hub racing clutch
-Custom front and rear tranny mounts with Poly inserts
Suspension/Brake Mods:
-Eibach Sportline Lowering Springs
-GM Performance front strut tower bar
-Baer vented/cross drilled front rotors
-Hawks HP pads
-Arospeed 17"x7.5" Hyperblack wheels
-Falken Azenis RT-615 tires on front, Hankook Ventus HR2 on rear
Exterior Mods:
-20% tint
Interior Mods:
-ProForm programmable shift light
-Dual gauge pod
President/Founder - 607 Motorsports
