Like pulling off a band aid…here we go…
For sale: 2002 Chevrolet Cavalier LS Sport (ECOtec ~ 76,000 miles)
Factory features: Power windows, Power locks, Power mirrors, Fog lights, Keyless entry with alarm, Trunk popper button, Map lights, 6 speaker premium sound, Cruise control, Cargo net, Intermittent wipers, Tilt Wheel, ABS, Traction control, Dual 12V outlets, and
Power Sunroof.
The good: Hasn’t seen winter since ownership at 23k miles. All fluids, filters, belts, and spark plugs are
changed yearly with OEM or better parts (this includes full synthetic oils for the engine and transmission as well as brand name filters and belts). Yearly wax and rain-x treatment.
Koni red shocks and struts have less than 15k miles. Tires have less than 3,000 miles. Rear drums have less than 3,000 miles. Rims have less than 15k miles (includes hubcentric rings). Brand new wiper blades. Brand new driver’s side power window motor. And of course,
Clean title and NYS inspection passed as of May 2011.
The bad: Minor paint chips and dings from normal driving. Driver’s side floor mat needs replacing. Keyless entry will unlock only the driver’s side door (not both). Keyless entry will set the alarm but will not lock the doors. When turning to the right, a noticeable hum can be heard. There is no detectable change in drivability. The noise has been present from ownership and the car has passed NYS inspection every year suggesting that whatever is generating the noise is not a safety risk. The charge pipe of the supercharger rubs the hood, this is purely cosmetic.
Included with the vehicle are:
HP Tuners Pro (with 2 credit for this car, 2 used for a friends, and 2 credits remaining for another vehicle). A Car Cover valued at $225 found here:
http://www.carcoverworld.com/lookup.asp?se=custom_car_covers&pc=noah. A CD with HPT files for stock and supercharger/transmission tuned will also be provided. Finally, all stock parts that I have will be included as well.
Modifications:
Engine:
RSM/Zspec Vortech Supercharger Kit (6psi)
*The most common issues with this kit were/are:
1) Oil leaking from the drive housing = I’ve upgraded the oil seal and bearing to eliminate this problem.
2) The belt slips at high rpms = I've managed to fit a belt that's 1 inch smaller than the one that comes with the kit. This belt is on tight and I see a full 6psi of boost.
3) No tuning = I've installed 370cc injectors and tuned the car with HP tuners
Ported Throttle Body (60mm)
370cc LSJ Injectors
HPT Tuned PCM
Mobil 1 Synthetic Oil
Royal Purple Full Synthetic ATF
Optima Red Top Battery
Suspension/Wheels/Brakes:
Koni Red Adjustable Shocks and Struts
RK Sport Coilovers with H&R Springs
Prothane Control Arm Bushings
17" Exel Ennio Silver Wheels
225/45/17 Falken Ziex Z-rated Tires
GM Front Strut Tower Bar
Custom Rear Strut Tower Bar
Factory Front Sway Bar
Eibach Rear Sway Bar
PowerSlot Rotors
Hawk Performance Brake Pads
Russell Braided Brake Lines
Weaver Premium Synthetic Brake Fluid
'Teh Jeffie' 1/2in Rear Hub Spacers
Interior:
Custom Red and Graphite Seats
Dark Charcoal/Black Headliner
Red Neon Lights Under Dash
Black Cat Custom 140mph Gauges
Dual Gauge Pod
Boost Gauge
AEM Uego Air/Fuel Ratio Gauge
Matrix Red and Black Sport Pedals
Shortened Automatic Shift Knob
HyperWhite LED Map and Dome Lights
Sunfire HVAC (lights up red)
Sunfire Power Window Switch (lights up red)
Red LED Shifter Bulb
Exterior:
Wings West W-Type Ground Effects Kit
Clear Corner Lenses
95-99 Tail lights
"Supercharged" Third Brake Light Cover
Shaved Emblems
Black Painted Calipers and Drums
Antenna X Shorty Antenna
9007ST Silverstar Headlight Bulbs
880ST Silverstar Foglight Bulbs
HyperWhite LED License Plate Bulb
Audio:
10" 500 Watt Alpine Type E Sub
250W Alpine Monopower Amp
Q Logic Subwoofer Truck Box/Enclosure
True 6 Speaker Premium Monsoon Sound System
Pontiac Monsoon CD/MP3 Player
Dynamat Insulated Trunk
Big 3 Wiring Upgrade
Miscellaneous:
Locking Gas Cap
Whistler 1730A Radar Detector
Custom "Ecotec 2.2 Supercharged" Emblem
"Mobil 1 5w-30 Factory Fill" Oil Cap
PICS!
Why I’m selling this car: As I drove into work/school this morning I had the sunroof popped open, the windows down, the music blaring, and the supercharger growling. The sun was out and it was an absolutely gorgeous day and all I could think about was: “Do I really want to do this?”. I’m not going to sugar coat it, there is a big part of me that really doesn’t want to let go of this car, but the reality is I’m past the days where a lack of responsibilities affords me the opportunity to spend my money modifying and/or maintaining two cars (summer vs. winter). I’ve considered holding off on modifying for a while, but there is no escaping routine maintenance on two vehicles. Not to mention that the demands of pursuing a doctorate in biomedical research leaves me so little free time that even trips to the insurance company and DMV twice a year every year become a burden. Additionally I’ve managed to pay off a substantial chunk of my undergraduate loans and if I ever want to pay off the rest, I’m going to have to make sacrifices. I’m also fortunate enough to have another clean, well maintained J, thus I can part with the more valuable of the two. I can’t wait for the days when I’ve completed my education and am established to the point where I can come back to the scene and pick up where I left off.
I’ve laid it all on the table. What you see is what you get. If you have any questions, please don’t hesitate to PM me.
PRICE = Best Offer
Thanks for looking!
